CODE P0304 1999 protege
Old 04-14-2006, 11:54 AM
FOSTER1234's Avatar
Default CODE P0304 1999 protege
Change coil for cylinder 4. Still missfiring, spark plug looks OK. Any ideas????
thanks, gary
Old 04-14-2006, 10:36 PM
babyhuey's Avatar
Default RE: CODE P0304 1999 protege
Should replace the spark plug anyway as a missfire can foul the plug even if it does look ok. Check for a vacuum leak at the intake manifold gasket. Spray a little carb or brake cleaner near the gasket and see if the missfire quits. Pay special attention to the underside of the manifold gasket area near the outer corner as this is a very common spot for the gasket to rupture.
techsupport
06-20-2011 05:07 PM
808mazdampv
04-08-2011 03:18 PM
ed4ward
01-30-2008 09:42 PM
Quick Reply: CODE P0304 1999 protege
