The carpet on the floor of the front passenger is wet
Old 04-08-2017, 02:03 PM
kathyfixit's Avatar
Exclamation The carpet on the floor of the front passenger is wet
1995 Mazda Protege LX 1.5L.
I just noticed that the floor on the passenger side in the front is wet. It seems to be only located on the floor board and not under the dashboard. It doesn't smell so I doubt it's coolant.
Can anyone please tell me what this could be?
Old 04-12-2017, 01:54 AM
Does it look or smell like coolant? Otherwise rain is getting in somewhere.
Old 04-12-2017, 10:18 AM
kathyfixit's Avatar
I was thinking it was the heater core as my heat never works but there's no smell to it.
Old 04-14-2017, 09:50 AM
Sparky202's Avatar
There is a drain tube for water to exit the air plenum. A/C dehumidifies the air and the water has to have a way out. Yes it's cooler out now, the A/C runs on defrost mode to dehumidify and clear the windows. The tube should be visible on the outside of the firewall towards the passenger side of the vehicle, or may be only seen from underneath. Either way, check there first
Old 04-14-2017, 10:33 AM
kathyfixit's Avatar
Thank you but I have no clue where this tube is located. All I see when I look under the dashboard is a BIG black part that's plastic and I believe the heater core is inside. Other than that the only tube I saw went to the blower motor and that shouldn't have come loose.
Old 04-14-2017, 01:42 PM
Sparky202's Avatar
Drain tube located on the outside of the vehicle. Wouldn't make sense to drain inside the car.
Old 04-14-2017, 02:06 PM
kathyfixit's Avatar
Look I never said it was outside of the car. I have no clue where this is.
Old 04-14-2017, 04:23 PM
Sparky202's Avatar
Sorry, the drain tube for the A/C is located on the outside of the vehicle. If and when it clogs, the water remains in the duct work and eventually spills out onto the floor, passenger side.
tonyd
02-10-2023 11:10 AM
carid
01-28-2015 08:41 AM
JimAlex
08-23-2013 06:22 PM
dvcwlc
09-03-2007 04:39 PM
Quick Reply: The carpet on the floor of the front passenger is wet
