Car clunk noise
Old 11-11-2014, 01:13 PM
Chris Ringler's Avatar
Default Car clunk noise
Does not make a difference if I am turning it is not suspension. It is clutch or transmission related. The noise is not as loud and sometimes completely stops if the clutch is disengaged. Does not make the noise I believe if going in reverse.
2000 Mazda Protege Front wheel drive manual transmission.
Old 11-11-2014, 03:43 PM
hixx's Avatar
Jack the front of the car up and run it in gear. You should be able to isolate the noise. Could be a worn out tripod (inner joint of the cv axle) Otherwise it could be inside the trans. Does the car vibrate on accel?
Old 11-11-2014, 03:49 PM
No vibrations its running normal other than the noise.
Old 11-11-2014, 05:27 PM
hixx's Avatar
It really sounds like an axle joint or warped bearing hub to me. It should be pretty obvious once you get the two front wheels off the ground and run it in first gear. Since there is no noise in reverse it would be more likely an axle noise since the excessive wear would likely occur with pressure from one side in forward gears. Reverse is only used .00001% of the time resulting in no wear to that side of the cv joint, thus no noise.
thundercatpt
11-14-2012 04:02 AM
asianstutter
10-12-2009 03:57 PM
mazdacreep
08-15-2008 03:31 AM
tdc100
05-16-2006 10:00 AM
tdc100
05-16-2006 09:55 AM
Quick Reply: Car clunk noise
