99 Protege with occasional hesitant acceleration, starts from stop with a jerk
Old 11-14-2016, 10:04 AM
bbortnick's Avatar
Default 99 Protege with intermittent alternator warning light forces transmission to 3rd gear
Hi, does anyone have a theory?
I have a '99 automatic Protege:
Symptoms:
1. When warm, the alternator light intermittently flashes. When this occurs, the car switches to and/or sticks in 3rd gear. Acceleration is very poor at this time. Goes away after a minute.
2. If the car is at a stop light when the alternator light flashes, the transmission will jerk when pulling away (forced switch to 3rd gear?).
3. While stopped at light (in gear,) the RPM may bounce between 750 (normal idle) and 500 (lights also dim at this time) and alternator light may flash on.
4. Moving the gear selector to 2 or 1 does not switch to the lower gears while the problem is occurring.
Notes:
1. 100,000k’s, not a lot of maintenance, except for oil and filter changes.
2. Always starts ok, and runs fine 90% of the time.
3. New battery installed
4. No loose battery cables
5. Transmission fluid is full
6. Cleaned throttle body and MAF sensor
7. Mazda dealer has done a basic electrical check, all ok (alternator putting out 14.5v).
8. Mazda indicates no error codes are stored in computer.
9. The check engine light does not come on (light bulb is ok).
Last edited by bbortnick; 11-14-2016 at 08:53 PM. Reason: more accurate symptom details
merlebh
01-07-2014 06:21 AM
alans2002millenia25
09-22-2013 08:34 PM
virgin1
04-12-2012 11:22 AM
GoldBuyer
07-27-2009 09:22 PM
BAABU
07-13-2009 07:01 PM
Quick Reply: 99 Protege with occasional hesitant acceleration, starts from stop with a jerk
