99' Protege, Drivers Side Lock Malfunction
Old 08-20-2016, 07:06 PM
tbishop's Avatar
Location: Southern California, Protege 320K and still going
Default 99' Protege, Drivers Side Lock Malfunction
Hi
I have a '99 Protege after 320K+ starting to lock me in on the drivers side all of a sudden.. I pull up on the opener by the glass and it just sticks, won't pull up, won't unlock the door, can't get out! If I use pliars to do it will finally give and the door will open in the safety latch so its not completely unlatched but the door has opened 1/4 inch then if you pull the handle inside or out you can get out... and close the door again. The button will or will not work for a while it's intermittent. Nothing I know of has changed on the car so I ordered off eBay a used 2003 door lock mechanism the part that latches to the door and connects, installed it and same thing except this one is newer and does not buzz when using the electric lock / unlock...
Any Ideas??? on what to look at next?
Thanks,
Thomas
1999millenia
03-31-2011 03:06 PM
alfy
08-11-2010 05:04 PM
mini kramer
09-17-2007 08:32 AM
cincera
03-06-2007 05:20 PM
itejeda
03-08-2006 01:03 AM
Quick Reply: 99' Protege, Drivers Side Lock Malfunction
