Heater Control Unit
Old 12-17-2014, 08:52 AM
louielace69's Avatar
Thumbs up Heater Control Unit
It has died on me
Any way to revive it or just replace it?
I'm gonna double check the fuse but I think it was good when I last checked
Thanks Dudes!
Old 12-18-2014, 11:11 AM
tanprotege's Avatar
Originally Posted by louielace69
It has died on me
Thanks Dudes!
Which dial, lever or button exactly has quit working?
Old 12-19-2014, 08:08 AM
Fan won't go to any speed
Old 12-19-2014, 03:22 PM
hixx's Avatar
It has a circuit breaker that resets itself. Most likely the brush's in the fan motor are worn out. Turn the fan on and bang on the motor under the passenger side dash. If it starts working replace the blower motor. If not you will need to test the connector at the blower motor for power and ground and work your way back to the switch. There is a blower motor resistor between the motor and switch for different fan speeds.
Old 12-19-2014, 08:06 PM
tanprotege's Avatar
Hixx is so good, he put me out of work single handedly.
One thing though: the speed selector switch is of questionable quality. If it fails it can fool you in thinking the resistor is bad. So before you spend money bench test these items so you replace the one that's bad. Don't ask me how I found out!
The problem with the switch is that it has an internal spring that pushes on one side only rather than evenly. Someone took a switch apart and inserted a second spring to make it even. It is "hackable".
Old 12-23-2014, 01:11 PM
I was gonna take it out but the left side doesn't wanna slide out
Is there a trick I should try?
I have the trim & all out
Thanks
Old 12-25-2014, 09:22 PM
tanprotege's Avatar
Thanks
Sorry, I don't know.
My heat selector sliders were operating very hard. I used silicone lube on them and did not remove the whole unit. My fan switch was not operating well but I found a work-around and did not repair it.
all the best.
urak92
07-25-2015 06:45 AM
DaveMX6Owner
04-19-2012 07:15 AM
gomazdago
09-25-2009 08:46 AM
kids
01-20-2008 10:47 AM
goterdid
01-22-2007 12:58 AM
Quick Reply: Heater Control Unit
