2000 Protege DTC p0118 p0171
RE: 2000 Protege DTC p0118 p0171
Did you check the standard tune up stuff, plugs, wires, cap and rotor. Also, when was the last time you replaced the fuel filter. These are things that might not show up as codes, but can cause other codes and symptoms to rear their ugly heads...
ORIGINAL: MazdaES
How does the temp gauge read? Since you have only one temp sensor, The wire splits and one goes to the instrument cluster and other to the ECM. If gauge operation is normal would be looking at computer or computer connection problem.
