02 Protege5 PO455 Help
Old 03-12-2011, 04:12 PM
rascal455ho's Avatar
Default 02 Protege5 PO455 Help
Replaced cap and still getting code.
Old 03-24-2011, 10:48 AM
vw.fe2o3's Avatar
P0455 possible causes:
-Purge solenoid valve malfunction
-Canister drain cut valve (CDCV) malfunction
-Loose, missing or defective fuel filler cap
-Charcoal canister malfunction
-Catch tank malfunction
-Check valve malfunction
-Rollover valve malfunction
-Cracked fuel tank
-Fuel tank component parts poorly installed
-EVAP hose damaged or loose
-Fuel tank pressure sensor malfunction
Old 10-04-2015, 08:26 AM
tankmaker's Avatar
Click on the link below:
Mazda Protege Workshop Manuals
In particular check out section 01-16 Emissions. Click on 01-16 and it takes you to the EVAP pdf
Rayzcar
05-17-2012 01:57 PM
Cramm557
12-01-2010 03:44 PM
AllGoNoShow
11-06-2010 08:21 PM
trixter3d
04-14-2007 08:32 PM
mmich101
01-16-2007 12:42 AM
Quick Reply: 02 Protege5 PO455 Help
