transmission safety switch location?
Old 03-13-2008, 07:35 AM
willy3486's Avatar
Default transmission safety switch location?
Can anyone tell me the location of the safety switch that keeps you from starting if the transmission is not in neutral is at? I think it is going bad and I want to go ahead and replace it. Can you bypass this for the time being until a person locates another? Is the switch inside in the truck beneath the console or will I have to remove it from underneath the truck?
Old 03-13-2008, 08:19 AM
Default RE: transmission safety switch location?
This depends if the truck is an automatic or a manual. If it is an automatic the switch is located around the shifter, there should be a coupling located under the console that connects to the tranny, you can unhook this but I'm not totally for sure if it will start, if it is a manual tranny then all you have is a clutch switch and it is located around the clutch pedal and is coupled to a bundle of wire in the foot area of the vehicle as stated before I don't know if you can unplug this and the truck run or not but you can always do a test on the circuit to see if the switch is bad.
Old 03-13-2008, 10:12 AM
willy3486's Avatar
The truck is a automatic. I may take the switch off and jumper it for the time being until I can locate the switch. Thanks
Old 04-17-2008, 02:15 PM
On my '90 b2600I its on the transmission, passanger side and its one of 2 connections coming out of the trans. Don't remember the wire colors in the connectors. Hope that helps !
brp223
08-04-2022 12:51 PM
sealuva
04-22-2014 05:20 AM
MyronCope
06-05-2010 02:15 PM
timaelabu
07-25-2008 11:37 PM
Natedogg
01-26-2006 12:49 AM
Quick Reply: transmission safety switch location?
