steering column noise
Old 02-10-2008, 11:20 AM
myb2600i's Avatar
Default steering column noise
i have recently bought a 91 b2600i cab plus. 222k miles. one owner and runs great. i have been fixing minor stuff on it and have found the post here to be very helpful. the steering column has a kind of erie moan while turning. anyone havean ideal how to lubricate it. also, at highway speeds a noise is coming from behind the gauges. maybe the speedo?sounds like a wind noise. any advise would be appreciated
Old 02-21-2008, 11:46 AM
Default RE: steering column noise
is it constant? is it only when it's cold out? i have an odd noise eminating from my gauge cluster (when it's cold) which presents itself at speed. i'm thinking speedometer cable?
Old 02-22-2008, 01:32 PM
On your steering column noise you need to remove the back housing, where the hazard switch is and lubricate the grommet in there with some silicone spray or WD-40.
Old 02-23-2008, 09:38 PM
myb2600i's Avatar
that sounds like a good place to start. i will remove the cover and try to lubricate it. thanks. the noise behind the gauge cluster is constant at highway speeds hot or cold. i think it is coming from the speedo cable.
Mazmart Trini
03-15-2012 09:27 AM
samjac68
07-01-2011 06:19 AM
matchboxcarz
03-23-2007 02:35 PM
crookedcolumn
09-07-2006 10:50 PM
crookedcolumn
09-02-2006 07:13 PM
Quick Reply: steering column noise
