Rims for B3000 1994?
Old Mar 22, 2008 | 12:10 PM
rcalzadilla's Avatar
Default Rims for B3000 1994?
I'd like to replace my stock 14x6 rims with 16 or 17 inches with higher profile tires. Make it look a little bit more like a truck.
How do I know what rim will fit? What are universal fit or how to use adaptors.
Any info will be appreciated.
tks
Old Mar 22, 2008 | 01:20 PM
Default RE: Rims for B3000 1994?
I can't answer most of your questions, but also be aware that when you got to a taller tire, your speedo and especially the gearing of the truck will be changed. You may be effectively changing the final drive ratio from 3.73:1 (or whatever the OE final drive gears are) to feel and act more like 3.08's. You'll lose bottom end power and torque. The extra wheel/tire weight will only reduce actually fuel mileage and to some extent, power.
Unless you plan to compensate with new rear gears or a speedo drive gear change, your speedow/read much lower than your actual speed and the odo will reflect fewer miles driven.
In_Titusville
Apr 21, 2014 11:12 AM
RichardLee4261
Feb 14, 2011 08:52 PM
tungul
Jan 25, 2009 03:58 AM
adixon816
Dec 17, 2008 07:06 PM
adenney
May 9, 2008 08:32 PM
