New here, 95 B2300 clutch replacement questions - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 07-21-2011, 03:21 PM
Default New here, 95 B2300 clutch replacement questions
Hey there. I'm brandspanking new, and I hope this forum can help me out. If so, I'll stick around and be a part of a new community.
I've got a manual 95 B2300 2.3 that has a worn out clutch, thanks to some idiot messing with kill switches and alarms and leaving some box thing under the flooring and behind the clutch, preventing proper movement. I bought a chilton repair manual, and it has some diagrams and the steps for replacement, but it totally skips over any of what I must do with hydraulics, bleeding, etc. I've NEVER do anything like this, only doing oil changes, a few belts, and an alternator. I have no clue what not to mess up, what steps to take, which ones are risky (rather, which ones need extra care), etc. I have never messed with hydraulics and the like, so can someone point me to some videos or a site that will help me learn what I'm doing first?
Also, in a bit of a rush I bought a Sachs clutch repair kit from O'reilly's. was this a mistake? Should I only go with OEM? What was OEM for 01/95 B2300s? The one I bought has a lifetime warranty, I thought that would make it a safe purchase, but now I'm wondering.
Old 07-23-2011, 01:00 AM
Cusser's Avatar
Sachs is a well-known clutch products manufacturer, OK by me. To replace the clutch, the transmission must first be removed, but you know that. The slave cylinder on the side of the transmission simply unbolts from the transmission during this repair and you tie it up out of the way; you do not need to disconnect its hydraulic lines at all.
Make sure to get a repair manual, lots of stuff to unbolt. Good luck. And remember a 1995 Ford Ranger is 99.9% the same.
Thread Thread Starter Forum Replies Last Post
94 Mazda B2300 Hydraulic Clutch Line Removal gojo Mazda Pickup Trucks 1 03-17-2011 09:40 AM
New clutch no pressure at clutch bleeder mazdaprotege97 Mazda Protege 0 12-24-2009 08:49 PM
94 Mazda B2300 Questions lost94 Mazda Pickup Trucks 1 04-17-2009 10:05 PM
B2300 Clutch issues MrGoodbytes Mazda Pickup Trucks 2 07-17-2007 06:56 AM
"97" B2300 trans questions dlite50 Mazda Pickup Trucks 0 03-24-2007 03:06 PM
Tags
95, b2300, cluch, clutch, cost, installation, instructions, manual, mazda, pickup, repair, replace, replacement, replacment, sachs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
