I can't pass smog test with Weber!!
Old Sep 10, 2008 | 07:25 PM
mtvjackass74's Avatar
Default I can't pass smog test with Weber!!
hello guys, I installed a Weber 32/36 back in Jan, well, today I went and had my truck tested for emissions, and it didn't pass. My HC and CO were high. Monday its going to the mechanic. What can I do to make it pass without taking it to the shop?? I also had a new cat put on saturday just in case, and it still didn't pass at all. I own a 87 Mazda b2000, great work truck!!
HC was 353 should be below 220 CO was 4.15 should be below 1.2. thx guys
greg
Old Sep 11, 2008 | 04:47 PM
GTFORZA's Avatar
Default RE: I can't pass smog test with Weber!!
I drive a 1990 B2200 with a WEBER and I had to do an EGR delete. The Exhaust Gas Return sends Exhaust back to the motor for emission purposes.
Old Mar 14, 2012 | 09:21 PM
trainwrecker's Avatar
Man I'm glad I live where emissions don't matter. Wide open. Sorry that truly does suck
Old Mar 15, 2012 | 02:51 AM
The Weber has replaceable jets. It needs to be tuned to your specific vehicle.
If you're HC & CO are bad, its rich at idle, if not all the time.
Increasing the air correctors, or downsizing the idle fuel jets is the way to go. One, or both may be needed to correct the over-rich situation. You might also look at the float bowl level to make sure it's not high.
You should not need to do an EGR delete to get it to pass inspection.
saldbar
Nov 20, 2012 02:59 PM
Adam3
Nov 1, 2011 05:13 AM
msharp
Nov 30, 2009 11:00 AM
04yamaha
Mar 24, 2009 08:53 PM
stanleymag
Mar 13, 2009 05:46 PM
