Help ! Intermittent starting 1993 B2600i 4x4
Old 05-05-2008, 09:31 AM
Dave P's Avatar
Default Help ! Intermittent starting 1993 B2600i 4x4
I never had a starting problem until one day the nightmare began . It would crank well but would not ignite. Somedays it would start. Once started , if I didn't pay attention , the RPM's would steadily drop and die out and would not restart. If I paid attention and kept the rpm's up by pressing the accelerator I would be fine and would not have a problem starting all day. The next day would be iffy all over again. Somedays I would be successful some not. It has been sitting for several days now and I can't get it started. Over this period I checked and replaced several items: (1) ignition -replaced distributor cap , rotor , wires and plugs - good spark from all wires and coil. (2) fuel delivery- checked fuel filter 30psi to filter and 39psi after filter. I replaced it anyhow. I pulled hose off fuel pressure regulator and no fuel dripped out. Yesterday after trying to start the truck i pressed on the accelerator then put it to the floor to drain off fuel-it seemed to want to ignite. I took out the plugs and they had fuel on them. Is my problem due to ignition system or a fuel delivery or something else ? Is the psi's quoted sufficient ? If I get gas on my plugs does this eliminate fuel pump problems ? Can this be a mass air flow problem or a fuel relay?
I need help ! Thanks Dave P
Old 05-09-2008, 07:35 AM
Default RE: Help ! Intermittent starting 1993 B2600i 4x4
Could be a MAF problem or it could just be a ECM problem, if you discover it is your ECM try AvPro ECM to have it repaired.
Old 05-15-2008, 03:42 PM
Dave P's Avatar
Bout 5-7 days ago I put in a new oxygen sensor- has started ever since with no problems.
Noticed almost no exhaust smoke, engine idles more smoothly.I'm happy I didn't have to pop for
a MAF sensor ( $ 299 ) or the labor for a new fuel pump - Now for the new pitman arm and I hope that's all.
Old 05-16-2008, 03:28 PM
mxer201's Avatar
ORIGINAL: Dave P
I don't understand how an O2 sensor would make such a big difference. Once when mine was idling, I unplugged the sensor just to see what would happen. Didn't change the idle one bit!!
Old 05-26-2008, 09:08 PM
Dave P's Avatar
Mxer201 You were right- OS2 seemed to work....for awhile... or I imagined the engine idled more evenly and there was no visible exhaust. Soon after the revs did fluctuate wildly. I think I'll have to take bigboss2010 advice and check out the ECM. I've read that the capacitors have a tendency to leak over a period of time and I now recall a faint odd odor before all these problems. Since this is an older vehicle these items would have needed replacing sooner than later. Now if only I didn't hastily pull the gas tank to replace the pump......damn
Old 05-27-2008, 11:58 AM
mxer201's Avatar
If you go the ecm route check this guy. He repaired mine in 04. So far no problems. Good luck.
http://www.avproecm.com/
oscar220
01-01-2010 02:29 PM
cperry
02-12-2009 11:59 PM
Dave P
06-02-2008 12:02 AM
JamesD
06-01-2008 08:53 AM
GRHoward1937
11-02-2006 12:16 AM
Quick Reply: Help ! Intermittent starting 1993 B2600i 4x4
