help with engine swap
Old 03-06-2008, 04:56 PM
bbyers's Avatar
Default help with engine swap
i am trying to find a engine for a b600i, does anyone know what engines will interchange with this engine, or know where i can buy one
Old 03-06-2008, 05:40 PM
Default RE: help with engine swap
i have worked with these trucks alot, and to my knowledge there are no engins that will bolt right in, The G6 engine shouldnt be hard to find, try your local scrapyard ( there are also a few on ebay). But other then that if you want to go with a different engine you will have to swap out the stock transmission or get a custom made bell housing.
Old 03-06-2008, 08:39 PM
I just went through this it is easier to call a local wrecker and see if they have one or just get one off ebay.
Old 03-07-2008, 09:51 AM
bbyers's Avatar
what is a G6 engine
Old 03-07-2008, 11:03 AM
The G6 engine is the series of engine that is in the 91-93 b2600i trucks. This is the motor that you are gonna want. There are several listed on ebay right now. You should check them out.
Old 03-07-2008, 04:38 PM
bbyers's Avatar
i was also told the engine out of the MPV van would also interchange, is this true?
Old 03-07-2008, 04:40 PM
Yes, I believe so.
mgnaflw_mzda3
02-16-2010 07:11 PM
fobmasteralex
07-20-2009 01:46 PM
swappyRx7
03-10-2007 02:06 AM
Badgett
10-02-2006 01:49 AM
Quick Reply: help with engine swap
