Fuel Pump B2600 1987
Old Sep 21, 2006 | 03:43 AM
TruenoAE86's Avatar
Default Fuel Pump B2600 1987
Hi, does anyone know where the fuel pump originally is located? mine was an electric fuel pump located near the engine it had some problems so they have putted them near the gas tank but still fails a bit.
Also, does anyone know how much is a carburetor for this truck? and where could i find one?
Thanks in advance.
Old Sep 21, 2006 | 05:09 AM
RawDawg's Avatar
Default RE: Fuel Pump B2600 1987
the fuel pump on these trucks are located in the gas tank. it is held in with 8 7mm bolt i believe, i just pulled mine out tonight.
Old Sep 21, 2006 | 05:11 AM
TruenoAE86's Avatar
oh thanks alot =)) because i need to check the fuel problem =S so the gasoline filter would be in front or still near the gas tank?
Old Sep 21, 2006 | 12:06 PM
RawDawg's Avatar
on mine the in tank fuel pump goes to the fuel filter that is rite beside the tank "that is stock" and then there is a cut off valve it goes into before it heads up to the engine bay where it goes into another fuel filter "not sure it's stock" before entering the carb. in the tank there is also a filter on the end of the fuel pump
Old Sep 22, 2006 | 05:43 AM
TruenoAE86's Avatar
Ahh thanks again i only found the filter behind it was complety dirty and blocked also another hose was blocked with dirt so i changed the fuel filter and the hose for new ones and the truck runs perfectly!, ive been havin problems with this since for months till now, our mechanic thought it was the fuel pump but it wasnt. Thanks again.
By the way do you know if they sell a carburetor for this mazda truck??
Old Sep 22, 2006 | 12:01 PM
RawDawg's Avatar
weber makes a kit for the mazda, i'm currently running one. here is the web page for them http://www.racetep.com/weber/mazdakit.html
Old Nov 11, 2012 | 05:37 PM
goodfellow's Avatar
My fuel pump on my 88 B2600 went south twice before the truck had 35K miles on it. The second time I left the old pump in place and just plumbed in a $30 off the shelf Purolator electric fuel pump right next to the fuel filter. The new fuel pump just sucks gas through the old in-tank pump without any problems. The truck now has 230K on it and I've never has a problem with the $30 fuel pump that I added over 20 years ago.
Hope it helps --
MrMotorHeadInSeattleWa
May 29, 2019 06:31 PM
2blue
Off Road
Oct 29, 2012 01:26 AM
firefighter3224
Oct 7, 2007 02:01 PM
CarlGran
May 30, 2007 05:03 AM
bluemagic
Oct 24, 2006 10:50 AM
