Fuel Problems
Old 02-15-2008, 06:38 PM
coldshot2's Avatar
Default Fuel Problems
I have a1993 b2600 4wd that just recently decided to quit starting. Have between 65-80 lbs. pressure out of fuel filter,have fire to plugs,will start on either. Would it be likely I have a pressure regulator problem.
Old 02-20-2008, 08:02 AM
Default RE: Fuel Problems
This could be very likely, I can't remember how much pressure you are supposed to have a the regulator, could also be a bad relay.
Old 02-20-2008, 08:57 AM
mxer201's Avatar
Have you ever had the ecm repaired? Check out this web site: www.avproecm.com He repaired mine almost 4 years ago and has worked fine since.
AntonA
08-24-2009 03:49 PM
Variety=Spice
10-11-2007 11:14 PM
UrbanmanUSA
08-04-2007 04:14 PM
1993mazdaMX6
03-31-2007 11:41 PM
quikgal
12-09-2005 11:43 PM
Quick Reply: Fuel Problems
