Fuel injected 92 B2200 won't start.
Old 01-30-2010, 08:19 PM
johnlangjohn's Avatar
Default Fuel injected 92 B2200 won't start.
We can get the engine to run if we spray ether in the intake or a little gas. Replaced the fuel pump with a new one. Replaced the under hood fuel filter. Injectors are getting a signal. Fuel pump does not pump when key is turned to on. Pump does pump when the engine is turned over and holds about 16lbs pressure.
Replaced the ECU with a used one from an automatic PU. No luck. Driving me crazy.
Please help.
Old 01-30-2010, 09:27 PM
Cusser's Avatar
What is the specification range for the pressure?? Is 16 OK?
Old 01-30-2010, 09:42 PM
I have not been able to find the fuel pump Pressure spec for fuel injection. Anyone know?
Old 06-16-2020, 04:27 PM
Spencer Hedge's Avatar
the line below the fuel filter should have above 38psi and the rail should be 11-20
I just swapped a efi motor from a 93 to a 92,
will run with fuel put into intake but, lots of pressure to fuel rail, and can hear injectors working, won't run,
kekoaenos
12-18-2008 01:02 PM
blue bu
01-29-2008 11:48 PM
Glen wentzell
12-02-2007 06:36 PM
sk8erman102088
05-11-2007 08:58 PM
guitar73
02-14-2007 03:32 PM
Quick Reply: Fuel injected 92 B2200 won't start.
