Flashers & Turn Sig not working
Old 03-25-2008, 09:48 AM
geotrac's Avatar
Default Flashers & Turn Sig not working
I have a 96 B2300 2WD 4 Cyl PU. The turn signals and emergency flashers have quit working. Have checked fuses but cannot find one out. Anyone have any suggestions on what to look for? Also does anyone have any information on how to changes plugs? This is a 4 cyl with 8 plugs and so far have only been able to find 4 of them.
Old 03-25-2008, 09:34 PM
Default RE: Flashers & Turn Sig not working
Not tottaly for sure on the sparkplugs but I think they are all the same. On your flashers try to find the flasher relay and see if it is properly working.
Old 03-28-2008, 06:36 PM
geotrac's Avatar
Where would I find flasher relay? It is not in fuse box under hood.
Old 03-29-2008, 11:04 PM
Here is what my manual says on these trucks:
Front seating area, driver side, under dash, driver side of steering column, mounted above parking brake cable.
Hope this helps.
Old 04-03-2008, 07:01 PM
cochleardad's Avatar
if your relay is fine this is usually caused by the indicator assembly inside of the steering colum and is very easy to change, salvage yard will be cheap and a dealer will usually be well over a hundred dollar, but this is a common problem with many vehicles, in fact i just changed mine on my b3000 just last weekend because of the same problem
Old 04-11-2008, 03:53 PM
This happened to me before and I was really angry. Turned out it was some faulty wiring, but this probably wont be your case. I'd Advise checking your fuses, and while your down there, might as well check all of them..
CanAva
06-09-2019 07:35 AM
izzyin stl
01-31-2015 04:25 AM
collier
01-25-2010 08:26 PM
dr4g0n3
03-21-2007 03:08 AM
6Pack
01-08-2006 05:32 AM
Quick Reply: Flashers & Turn Sig not working
