Engine problems!!!!
Old 12-05-2007, 02:40 PM
jmwaters's Avatar
Default Engine problems!!!!
Hey
I have a 99 b2500 manual, and sometimes when i want to stop or slow downata light oranywhere i put it in neutral, coast, and use my braketocome toa stop. This is where my problem is!!! As i start to slow down my RPM gage starts shooting to 4000 rpms and my engine starts screaming! This continues until i come to a complete stop!! It freaked me out the first time but now its getting annoying! Anyone have a clue as to whats going on????
J
Old 12-05-2007, 03:17 PM
sstlaure's Avatar
Default RE: Engine problems!!!!
Are you pushing the brake with your left foot with your right foot still over the gas? With the car out of gear, if you barely even touched the gas pedal with that right foot it would make it rev up.
Try braking with your right foot. (if you aren't already.)
Old 12-06-2007, 02:43 PM
jmwaters's Avatar
No thats the thing if i just put it in neutral and not touch the brake or the clutch the rpms will still start to rise to about 4000 and then i come to a complete stop and then it goes down!
Old 12-07-2007, 07:40 PM
sticky throttle maybe, try some lube on the throttle and make sure the cables are free
Old 12-09-2007, 01:20 PM
jmwaters's Avatar
thanks ill give it a try
Old 12-17-2007, 01:12 PM
Dont use wd-40 as lube... it collects dirt and dust... use motor oil... It works the best. I actually used gear oil that comes in a bottle that you can squirt out the little nipple thing...
Old 12-17-2007, 09:19 PM
use some intake air celaner to clean the TB and that should do it if its sticking.
Old 12-18-2007, 11:19 AM
jmwaters's Avatar
I've got some Pennzoil SUZ motor Oil
basil
10-19-2005 11:07 PM
bhasting
10-04-2005 10:57 PM
thakid22
08-26-2005 05:16 PM
skiman
08-13-2005 10:34 PM
mod10
04-11-2005 09:14 PM
Quick Reply: Engine problems!!!!
