Fuel pump problems
Old 10-10-2008, 06:39 PM
Roamer007's Avatar
Default Fuel pump problems
My b3000 sputtered and die yesterday, cost me a tow. I changed the fuel filter and still nothing, so I pulled the gas tank and replaced the fuel pump. Progress, the truck starts and runs but idling at 3000 rpm's. No adjustment was done to the idle set screw and the truck idled fine before. does anyone have experience with situation before? I don't know where to look next.....help
1994 b3000
thanks\
Old 10-11-2008, 04:54 PM
Default RE: Fuel pump problems
Did you ever get an answer or figure out what the problem was?
Old 10-11-2008, 09:40 PM
Roamer007's Avatar
no still stuck.........
Old 10-12-2008, 03:45 AM
Is it safe to assume that you have gone back and checked all the vacuum hoses?
Does the truck have A/C? Sometimes there is an idle increasesolenoid that allows more air directly in @ the intake manifold or carb base to bringup the idle when the eng is under load from the A/C compressor. Could thathave been activated (if it has one?)
I would think it has got to besomething pretty simple?
Old 10-12-2008, 09:40 AM
Roamer007's Avatar
I'll take a look at that.thanks
I was look over the truck today I thought it might be a pressure problem with the fuel line so released pressure at the fuel rail a couple of times, thinking maybe air was traped in the line. I also found out that the engine will stall if I disconnect the breather hose from the clean air box. This doesn't make any sense to me why it would stall after get unrestricted air flow.....
Old 10-13-2008, 12:03 AM
When you disconnected teh breather line from the air box it allowed the engine to suck in air that wasn't being measured by the airflow sensor which would cause a really lean condition... Although normally by doing this it willjust idle very rough...This makes me think you may have a vac leak somewhere past the throttle body..... The next though would be by some chance that maybe your idle air valve took a crap the same time your fuel pump did....
Old 10-13-2008, 05:44 AM
Roamer007's Avatar
I've checked for vac leaks and can't locate any. I did change the air idle control motor(iac) and the idle came back down to normal, but it only lasted untill the next time I started the engine and then back to 3000rpm's. I think it might be my mass air flow sensor(big$)hope it not. I have to read the computer to find out whats happening. I miss the caburator days...before computers.
Ronny64
05-13-2012 07:30 AM
lippert02
02-17-2012 12:30 PM
mad proffesor
02-13-2008 08:10 AM
Variety=Spice
10-11-2007 11:14 PM
rdunn
08-14-2004 02:48 AM
Quick Reply: Fuel pump problems
