Bucking B2300(egr)
Old 03-21-2013, 11:28 PM
Michael Chapman's Avatar
Default Bucking B2300(egr)
I have an 02 mazda b2300 and recently it started jerking very bad while accelerating and seems to lose all power when this happens. it usually goes on for a few minutes and then runs fine again for a few minutes and start the process over.
truck starts fine and idle fine. after searching everywhere ive found possible problems
1. EGR
2. coolant temp sens
3. vacuum leak
the egr sounded promising but i could use some feedback from someone who know much more than I
Old 08-17-2013, 08:00 PM
captarne's Avatar
I have a similar problem, my 2003 b2300 statred bucking at low speed the other day, worked fine on the highway.
Old 08-17-2013, 10:36 PM
tanprotege's Avatar
Start with the basics:
check or replace plugs and wires, they have 8! Get Motorcraft or NGK plugs, don't experiment!
clean the throttle body and Idle Air Control Valve.
Clean the MAF sensor.
Look for vacuum leaks.
Report back.
rzedman
04-28-2020 09:55 AM
Tjkapp
12-16-2014 02:26 PM
Waterlogged
05-21-2007 06:16 PM
theorc
03-01-2007 11:08 PM
hz91mc
10-08-2006 12:29 PM
Quick Reply: Bucking B2300(egr)
