B2600i Quits after a few minutes
Old 03-06-2015, 07:50 PM
B-T-S's Avatar
Default B2600i Quits after a few minutes
Hello,
I'm running out of ideas with my '93 B2600i, I bought it running but it was hard to start and it had no power when accelerating. It started getting worse and then to the point it quit and it would not restart? I ended up parking it for a few months. I then replaced the spark plugs, plug wires, distributor (old one was junk), coil, also rebuilt the ECU and I just replaced the coolant temp sensor. Before I got it someone else replaced the injectors, mass air flow sensor (used but it checks out ok) and then some other parts that I can't think of.
After replacing the ECU and Coolant temp sensor (old one check out bad) it now starts right up with out even thinking about it and then it runs for a couple minutes and then shuts it's self off. It doesn't even sputter, just like the key was turned off. There is no smoke out the tail pipe and there are also no noises or any other concerns. The pickup will not start again until it sits for at least 8 hours and then it does it all over again.
Tonight I pulled and tested the O2 Sensor and I believe it is bad. but I don't think it will cause my problem will it? I also tried starting it with the O2 sensor unplugged and it didn't do anything?
If anyone has any ideas please let me know, this little pickup is in really good condition otherwise.
Thanks for any advice.
Old 03-07-2015, 08:52 AM
hixx's Avatar
I have replaced a ton of injector harness's. The harness has crimped connections that lose connection and pull too many amps resulting in a fried ECU. You need to figure out what it is losing. Spark/fuel pressure/fuel injector pulse.
Old 03-08-2015, 09:12 AM
B-T-S's Avatar
It has spark when it quits, it also has goo fuel pressure. I'm going to check the injectors today
Thanks
Old 03-08-2015, 10:18 AM
hixx's Avatar
The crimped wires go to the fuel injectors.
ltd
08-21-2011 12:35 PM
motoX69
04-22-2010 07:33 AM
mabus the 3rd
04-05-2008 12:05 AM
mgulotta
08-01-2006 07:13 AM
superMan
03-31-2006 10:31 PM
Quick Reply: B2600i Quits after a few minutes
