B2200 check engine light
Old 01-29-2015, 05:27 PM
Mr_Leffe's Avatar
Mazda tells me I have to buy the whole Valve ($304) part #20-300
Old 01-29-2015, 06:18 PM
hixx's Avatar
Sounds about right. They used to sell it seperately but that was a long time ago and they were covering half of them under warranty. Try taking it apart and cleaning it. If that does not work then you will either have to replace it or put up with the light.
Old 01-29-2015, 06:27 PM
Mr_Leffe's Avatar
I wish it was that simple... To pass the SMOG test no engine lights can be on at idle. The EGR may be wore out anyway.. Diaphram?
Old 01-29-2015, 09:01 PM
hixx's Avatar
It is more likely a bad sensor or sticking valve from carbon accumulation. 3 bolts and 5 minutes of cleaning should tell the story.
Old 01-30-2015, 07:46 AM
Cusser's Avatar
I've got two working used B2200 EGR valves available, WAY cheaper than that (in Arizona). The valve operation of each has been checked with a hand vacuum pump; both open when vacuum is applied, and both close when vacuum is released.
The brown stuff on the one is Permatex, I can remove that with alcohol.
My E-mail is cussboy at *** dot net
Old 02-02-2015, 02:24 PM
Mr_Leffe's Avatar
I removed the EGR and cleaned a coalmine of carbon out. Replaced the unit and the Check engine light now gone. I did find an uncapped vac hose on the right side of carb base. Engine appears to run the same plugged or not. The left side one disappears in a harness of its brothers. Any knowledge where the loose boy is supposed to attach to?
Old 02-02-2015, 02:38 PM
hixx's Avatar
Not without a picture. Those have a ton of vacuum lines.
Old 02-02-2015, 03:17 PM
Mr_Leffe's Avatar
The one with the Golf Tee. Does it connect to somewhere under the Air Cleaner?
pdw001
12-05-2022 02:54 PM
brave-heart
04-21-2010 07:44 AM
Ksemerdjian
02-27-2010 10:03 AM
bassfishga
07-11-2008 03:44 PM
bassfishga
07-01-2008 12:33 PM
Quick Reply: B2200 check engine light
