98 B4000 warning beeps 25 times on start!
Old 05-05-2008, 05:34 PM
el cheffe's Avatar
Default 98 B4000 warning beeps 25 times on start!
New guy here wondering about beeps on start-up. I have a 1998B-4000 V6 2WD. It happens a few seconds after every start up.I get 5 sets of 5 beeps totaling 25 annoying beeps. I've checked the net with no results. Could someone please let me know what the truck might be telling me?
Old 05-05-2008, 07:14 PM
Default RE: 98 B4000 warning beeps 25 times on start!
http://www.rangerpowersports.com/for...d.php?t=226861
near the bottom it says this
" when the airbag light burns out or is otherwise disabled, Ford provides an audible backup. It is a group of 5 low beeps, then a pause, repeated 5 times. Your airbag problem has not gone away; the warning method has just changed from a light to the 5x5 beep.
A working airbag light will flash out a trouble code pattern that can help you diagnose the problem. Until it is repaired/replaced, the only way to read the trouble code is with a dealer tool. "
so maby its that ! other then that just call the dealership and ask the service desk about audible beeping codes. just even to know for fact there is something to look for and which direction to take.
Old 05-06-2008, 01:55 AM
el cheffe's Avatar
sounds about right,maybe. i know that before the beeps, theairbag light would have a pattern of blinking. i've tried using the key to turn the passenger airbag on and off, but maybe didn't work. i've been in a fender-bender or two and bags didn't deploy. maybe since i had bought it used, it had been in a prior accident. i will try again. but what change it from air-bag light blinks to beeps? is it like SpaceBalls? "i've lost the bleeps, the sweeps, and the creeps? thanks for the direction tho.
hairyg#3
11-19-2013 03:50 AM
emg2882
07-27-2012 06:21 PM
DaveD9900
02-19-2012 01:22 PM
garyevs
05-31-2011 01:56 AM
Luvmyrx7
12-30-2008 03:54 PM
Quick Reply: 98 B4000 warning beeps 25 times on start!
