93 b2200 dash lights
i had bought the truck and the dashlights never worked i tried looking for the fuse but i dont see any fuses for the dashlights..im getting power to the dashlight dimmer **** if any1 could help me that would be great thanks.
RE: 93 b2200 dash lights
OK. Now (with the light switch "on") measure the voltage coming out from the dimmer ****, first try at both extremes of rotation of the ****. If you don't get voltage either way, and in the intermediate positions, you have a bad dimmer switch. You can try a jumper wire to ensure that the rest of the circuit is OK, and the dash lights should then come on. If you can live with dash lights just being "on" when the lights are on (without having adjustment capability) just bypass this switch. I did just that on my old VW bug when its dimmer portion of the switch shorted out; then it essentially comes on same as the parking lights coming on.
ORIGINAL: baggedb22
i tried jumpering my dimmer **** thing and it didnt work and i checked for voltage there was nothing coming threw
So was there current going to the dimmer switch when the headlights were turned on? Post back with that information. If so, what happens when you "jump" the dimmer switch (with the headlight switch on, of course)? Post back with that information. What were you using to ground your test light or voltmeter when you did this test? Post back with that information.
there was no current goin "through" when the headlights were on. when i jumper it nothing happens. my tail lights/turn signals n everythin work exept the dash lights and heater control lights.i was using my ignition to ground the volt meter
So was there current going to the dimmer switch when the headlights were turned on? Post back with that information.If not, I'd personally tap into the parking light circuit and have them come on whenever the parking lights are on. What if the parking lights and taillights also don't work - then you've isolated the problem - work back to the light switch.
jpaschal21
06-17-2009 06:56 PM
anthonytsi
11-12-2008 04:37 PM
