92 B2600 4X4 Idle
Old 08-07-2007, 02:53 AM
shelakio's Avatar
Default 92 B2600 4X4 Idle
I have been having this idle problem with my 92 B2600 4X4. When the engine gets warm and I turn off the engine. On restarts in neutral(5spd manual) truck idles fine at about 700rpm. When putting shifter into any gear 1st to reverse, the idle would drop low to 400rpmuntil I put it back into neutral. After running truck for awhile, then it would be ok.It is not a big concern but when you are going at a slow speed 10mph and you come to a stop in gear with the clutch pushed in, sometimes eng would stall. Any ideas?
Old 08-09-2007, 11:33 PM
Default RE: 92 B2600 4X4 Idle
sounds like your clutch is'nt disengageing all the way. there should be a place to adjust it. do you have a manual ? that will tell you how to do it. it should'nt make any difference in gear or in neutral, and no grinding when you put it in first or reverse. hope this helps.
Old 08-14-2007, 02:01 PM
I have the exact opposite happening. When i put it in any gear while idleing it revs up. I dont knwo what it revs up to but it does rev up, quite a significant noise change so i know its abit higher. Is this normal?
Old 08-27-2007, 01:06 PM
hixx's Avatar
Check the clutch switch. Pushing the clutch in is considered a load on the engine and the PCM should kick the idle up. I have seen a few bad PCM's but more likely the clutch switch.
Old 08-28-2007, 09:56 AM
Similar problem with 99 B2500. Starts normal-runs normal. But when I come to a stop (usually first couple after start driving) it will stall like if you didnt push in the clutch, I think I notice that when I 'really" push hard on the clutch it wont happen as much. The idle speed seems ok. When it stalls I get the idiot red light for "battery" and "check guages."
Old 04-01-2008, 12:42 AM
oscar220's Avatar
I have had same problem for years. After reading about truck ECM's going bad I decided to check mine.Sure enough the resister leaked electrolite around it and there is obvious damage to the board. Now I just have to send it to AVPro in Florida to get it fixed. My feeling is that could be our problem.
Old 03-25-2009, 03:34 PM
oscar220's Avatar
Default Idle Problem
I sent my ecm for refurbishing(it looks brand new) and still have the same problem with idle.(though it ran better) It's generally around 550-650 rpm's and drops lower when clutch is in in gear,which makes engine stall.I've spent hundreds of dollars at the mechanic trying to get this fixed.They usually just work on the timing,which doesn't help.I've done everything except for a fuel pump and rotor.Does the clutch sensor affect idle as mentioned? What else affects the idle?
2blue
Off Road
10-29-2012 01:26 AM
varbcorp
06-19-2006 02:43 AM
varbcorp
06-09-2006 10:26 PM
90B2600I
11-04-2005 10:37 AM
ABTireman
06-03-2005 03:09 AM
Quick Reply: 92 B2600 4X4 Idle
