91 b2600i overheating - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 08-02-2012, 06:12 PM
Default 91 b2600i overheating
I have a 91 b2600i 4x4 and I have flushed the radiator , changed the thermostat and it is still overheating doesn't seem to have blown head gasket . Engine only has about 13000 miles since overhaul . Any help appreciated . I am also having problems getting the 4x4 to engage seems to try to go in by itself sometimes I have to put in 4x4 and then out again while moving to keep it from grinding . When it does go in it will pop in the front end and then go ahead and work .
Old 08-02-2012, 06:46 PM
Does your water pump work? Take off the radiator cap (COLD engine), start the engine then rev it up, if the water gets sucked down then it works, this might be more difficult if the cap is not on the radiator itself but on an expansion tank.
Old 08-02-2012, 07:35 PM
One thing to start with, is it overheating, reading a guage should be verified unless it is blowing steam ect.
Thread Thread Starter Forum Replies Last Post
87 B2600i rear differential fit in a 1990 B2600i? hugh2293 Mazda Pickup Trucks 1 09-29-2009 07:37 PM
Will 94 B2600i center console fit 90 B2600i acflye Mazda Pickup Trucks 1 04-15-2007 12:51 PM
Car overheating danattamco Mazda Millenia 11 04-26-2006 04:09 AM
engine overheating while idling? supabenben Mazda 323,Mazda 626 & Mazda 929 3 08-31-2005 08:29 PM
Overheating muddytazz Mazda Protege 0 06-19-2005 02:55 AM
Tags
4x4, 88, 91, b2600, b2600i, flushing, head, heating, mazda, metal, motor, overheating, problems, radiators, replacement, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
