90 mazda b2600 problem
Old 03-13-2008, 09:01 PM
poboy's Avatar
Default 90 mazda b2600 problem
The engine will crank and run as long as you keep the key held to keep starter engaged,when you turn loose the key it will go dead.Is the problem the key switch or something else?
Thanks
Old 03-13-2008, 10:38 PM
Default RE: 90 mazda b2600 problem
kes the key switch is bad ...to test it.....run a wire from the + side of your battery to the + side of your coil and start the truck if it runs then the switch is bad...but remember you need to puill the wire to turn off the truck
lazydrifter
01-25-2009 03:38 AM
808countryside
02-22-2008 09:33 PM
808countryside
07-01-2007 12:06 AM
bluemagic
10-24-2006 10:50 AM
bhc6
03-04-2006 10:59 PM
Quick Reply: 90 mazda b2600 problem
