89 b2000 engine knock help!!!!!!
Old 03-17-2009, 09:40 PM
drbigknuckles's Avatar
Lightbulb 89 b2000 engine knock help!!!!!!
have a loud tapping from my engine sounds like a valve tap. just statred doing this one day going to work. truck has about the same power when this started and runs fine just taps loud at all times now. i took the valve cover off and checked my rockers and valve springs they all looked good engine has 200,000miles i guess its time for a new one anyone. anyone else have this problem. p.s engine has hyd rockers so i cant adjust them at all im guessing??
Old 03-18-2009, 06:41 AM
hixx's Avatar
It sounds like it needs HLA's ( hydraulic lash adjusters) and or rockers and shafts. It's not a difficult job. Remove the valve cover and rocker shafts with rockers. Lay them out on a table and completely disasemble the rockers from the shafts and check for wear on the pivot points of the rockers and shafts. If there is no excessive wear you can just pop the HLA's out of the rockers and replace them. If there is excessive wear on the rockers/shafts you will have to replace the rockers and shafts which can be quite expensive.
If you can find an old B2000 head/valve cover you can switch it over to adjustable valve rockers. The valve cover from the B2000 will have to be used if you do that.
Old 03-20-2009, 03:14 AM
thanks for the help.. i took the rockers off today and found the one of the taps on the hydo rocker is stuck in i was going to get a new rocker and found that they are like 50 bucks can i just replace the hyd adjuster tap or get a whole new set of manuial adjust rockers??
Old 03-20-2009, 08:47 PM
hixx's Avatar
You can replace just the HLA. They pop right out with pliers. You can manually pump the new HLA up before installation and flush your old ones by holding it down into a cup of oil and pushing the checkball in the end of it in with a paperclip while pushing the plunger. Then just release the plunger and it will suck new oil into it.
jwong
02-26-2013 11:58 AM
kevindakota00
10-11-2012 09:32 AM
loup_cool666
03-03-2010 08:54 PM
Tfrag14
02-13-2010 02:02 PM
dericsh
12-19-2006 06:45 PM
Quick Reply: 89 b2000 engine knock help!!!!!!
