88 mazda b2200 performance mods - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 07-27-2005, 06:19 PM
Default 88 mazda b2200 performance mods
I have a 88 mazda b2200 5spd. I was wondering if anyone knows of any good mods. I have a Summit high performance coil, and a K&N drop in filter. Are there any free mods I'm not aware of(I know about port/polish). Open air intake? EGR delete? I'm doing an electric fan next, any suggestions?
Thanks,
Justin
Old 07-28-2005, 11:31 PM
Default RE: 88 mazda b2200 performance mods
There is too much info for me to give here not to mention I plan to copyright my site soon.
My site and forum is:
MazdaTruckin.com
B2200 Section
(Note: I'm still in the process of moving stuff to my new server.)
I can say that removing the EGR isn't going to do much and after doing some testing on the flowbench porting and polishing will most likely do a lot more damage than good unless you REALLY know what your doing.
Biggest bang for your buck is a Weber carb and better exhaust (nothing above 2" pipe).
Old 07-29-2005, 04:51 PM
If I want to put a header on I'll have to remove the EGR? I always see pics of an open air carb cover lid on the Carter carbs, can I do that with the stock one? How much do the Carters run? Full exhaust(with header), elec. fan, and carb should kick gas milage up pretty good?
Old 08-03-2005, 09:25 PM
Um, I've never seen a Carter carb on a B2200. The most common carb used for performance is the Weber 32/36, anything else is an adaption. The EGR system is built into the intake manifold and #1 exhaust port in order to actually remove it you would have to do some pretty heavy mods. As long as everything is hooked up to the EGR valve and it is still installed it will still operate. All the stuff going to the stock air breather is for the PAIR system that allows the exhaust to suck in fresh air to burn off emissions in the cat. That would have to be removed with either headers or a carb. With a little fabrication you could adapt the stock air breather to an aftermarket carb but unless you REALLY want to keep it on there it will be removed with a set of headers.
Thread Thread Starter Forum Replies Last Post
performance mods for my 1992 mazda protege? 1500cc lordcaocao Mazda Protege 1 07-17-2009 12:28 AM
Performance Mods to an 06 Miata? TigerSpeed Mazda Miata (MX-5) 1 08-24-2007 09:09 AM
Where do i find more performance mods adam3250 Mazda6 10 03-20-2007 02:45 PM
1993 Mx-6 Performance Mods 97Cobra Mazda MX-3 and Mazda MX-6 0 03-14-2007 05:21 AM
Where do i find more performance mods adam3250 New Member Area 1 03-09-2007 04:02 AM
Tags
aftermarket, b2200, breather, carb, carburetor, egr, forum, headers, jets, mazda, mods, performance, put, valve, weber
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
