88 MAZDA B2200 NO ACCLERATING ON HILLS, DIES
Old 09-19-2007, 02:58 PM
zero26's Avatar
Default 88 MAZDA B2200 NO ACCLERATING ON HILLS, DIES
HEY FELLAS, MY B2200 HAS GOT A PROBLEM, IF I AM SITTING ON A HILL NOT EVEN A STEEP HILL, I PRESS ON THE GAS AND THE ENGINES SHUTTERS, AND THERE IS NO POWER, THEN IT DIES. I HAVE TO PULL OVER AND WHILE ITS BARELY RUNNING KEEP PUMPING THE GAS TO KEEP IT GOING, THEN A MINUTE LATER IT WILL START RUNNING GOOD AGAIN. IT DOES'NT MATTER IF YOU ARE AT A STOP OR AT SPEED. I REPLACED THE EGR VALVE, NEW PLUGS AND WIRES, NEW FUEL PUMP AND FILTER, ALSO THE GAS GAUGE DOES'NT WORK, I DONT KNOW IF THATS CONTRIBUTING TO IT. THANKS SO MUCH!
[/align][/align]
Old 09-27-2007, 07:03 PM
hixx's Avatar
Default RE: 88 MAZDA B2200 NO ACCLERATING ON HILLS, DIES
Possibly fuel contamination. They had a problem with the tank coating coming apart. Also water seperates in a gas tank from the gas and wanders around the tank in pockets. Could be if on a hill it picks it up.
Old 09-27-2007, 11:48 PM
sounds like you have some obstruction in your gas tank..same thing happened to me it was the cardboard out of the lid of some fuel additive took it out hasnt had a problem since
Old 05-13-2008, 08:04 AM
Check the timing belt, myb2200-92did the same, after i changed the water pump.
Old 05-13-2008, 05:08 PM
i'd go carb. float valve or something of the like.
Old 05-14-2008, 12:15 AM
accelerator pump. whatever, carb problem.
Old 05-14-2008, 11:42 AM
Check the timing belt alignment marks!!
kyleagrant
12-23-2009 02:33 PM
spoil_kid123
12-03-2007 07:44 PM
legacylight
09-28-2007 01:50 PM
threeofive
07-05-2007 07:00 PM
JohnS54Coupe
05-18-2007 10:28 PM
Quick Reply: 88 MAZDA B2200 NO ACCLERATING ON HILLS, DIES
