87 Mazda B2000 dies/cuts off suddenly
Old 09-02-2010, 12:32 AM
Chiz's Avatar
Default 87 Mazda B2000 dies/cuts off suddenly
Hello, I am having a hell of a time diagnosing my 87 B2000. I cannot figure out why the engine suddenly dies? I have replaced the filter. its getting enough gas, maybe to much, because the level of the gas on the carb sight glass is on the upper side, not the middle as it is supposed to. I have swapped coils with my other b2000. The engine purrs like a cat, but then suddenly turns off, just like if you were to turn off the ignition. It will do it if you let it idle for a few minutes and it will tend to to it as well if you give it gas. It is responsive throughout the revs, but then just suddenly cuts off? Then it will fire up again once you turn the key to start it. It doesnt cough or start sputtering. It just dies suddenly and randomly. Any thouhgts would be much appreciated.
Old 09-08-2010, 07:25 AM
Cusser's Avatar
Your problem sounds more like spark issue than fuel issue, that's first part of a diagnosis.
These trucks are known for electrical portion of ignition switch going out, as they age, so check that out first, happened on my '88 B2200 about a decade ago.
If that checks out OK, suspect ignition pickup/ignitor inside the distributor.
itsmehb
08-14-2013 07:27 AM
dbclark44
01-12-2011 04:59 PM
sherrid36
06-13-2008 10:19 AM
tifftwins
10-18-2007 06:58 PM
aechicken
04-07-2006 11:32 PM
Quick Reply: 87 Mazda B2000 dies/cuts off suddenly
