87 Mazda B2000 dies/cuts off suddenly - Mazda Forum - Mazda Enthusiast Forums
LinkBack Thread Tools Search this Thread
Old 09-02-2010, 01:32 AM
Default 87 Mazda B2000 dies/cuts off suddenly
Hello, I am having a hell of a time diagnosing my 87 B2000. I cannot figure out why the engine suddenly dies? I have replaced the filter. its getting enough gas, maybe to much, because the level of the gas on the carb sight glass is on the upper side, not the middle as it is supposed to. I have swapped coils with my other b2000. The engine purrs like a cat, but then suddenly turns off, just like if you were to turn off the ignition. It will do it if you let it idle for a few minutes and it will tend to to it as well if you give it gas. It is responsive throughout the revs, but then just suddenly cuts off? Then it will fire up again once you turn the key to start it. It doesnt cough or start sputtering. It just dies suddenly and randomly. Any thouhgts would be much appreciated.
Old 09-08-2010, 08:25 AM
Cusser's Avatar
Your problem sounds more like spark issue than fuel issue, that's first part of a diagnosis.
These trucks are known for electrical portion of ignition switch going out, as they age, so check that out first, happened on my '88 B2200 about a decade ago.
If that checks out OK, suspect ignition pickup/ignitor inside the distributor.
Thread Thread Starter Forum Replies Last Post
Mazda 6 cuts off at times. itsmehb General Tech 4 08-14-2013 08:27 AM
Help! Mazda Millenia Cuts Off When Idling dbclark44 Mazda Millenia 0 01-12-2011 05:59 PM
1994 Mazda 929....cuts off when slow down or stop.....vacuum leak? Also, I need a repair manual! sherrid36 Mazda 323,Mazda 626 & Mazda 929 2 06-13-2008 11:19 AM
2004 Mazda MPV cuts off while driving no engine light tifftwins Mazda MPV 1 10-18-2007 07:58 PM
b2000 dies after its been running awhile aechicken Mazda Pickup Trucks 2 04-08-2006 12:32 AM
Tags
87, b2000, change, chargers, cutting, electrical, forum, ignition, mazda, problems, replace, shut, shutting, suddenly, super, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
