1998 Mazda B4000 vibration at around 70MPH
Old 06-10-2013, 11:20 AM
1998mazdadude's Avatar
Default 1998 Mazda B4000 vibration at around 70MPH
Hello,
Have a 1998 Mazda B4000, just recently did the spark plug change and went through the passenger side wheelwell. Had no vibration above 70 until after the plugs were changed. Runs smooth until about 70 and then the rear starts to shake, mostly when i have a load in the bed. Any Ideas on a way to stop the vibration...?
Thanks
Tim
Old 06-10-2013, 11:52 AM
If they removed the tire (front tire!?----yet rear shakes?!), it's possible they got dirt in between wheel and hub and/or did not properly torque it.
Did they rotate tires?----rear shakes?
Old 06-10-2013, 12:04 PM
It shakes more when there is a load in the bed. Did not rotate tires yet... Rear of truck shakes. Steering wheel does not shake at all...
Old 06-10-2013, 02:34 PM
tanprotege's Avatar
Mazdadude: Check the tire pressure.
Consider rotating the tires to see if the shake moves somewhere else. That would proof that the problem is related to the tires.
If you do it yourself: inspect the tires for uneven wear and cracking rubber on the tread and in the side walls.
If you take it to a shop ask them to check the balance of the tires.
If you have alloy rims the lug nuts need to be torqued again after about 100 miles of driving.
I think the timing is coincidental. Taking your front wheel off does not cause a shake in the back.
Old 06-10-2013, 04:01 PM
Thumbs up
You said what I was thinking!
Thanx for the clarity.
Old 06-10-2013, 04:40 PM
Thanks guys. I'll check into everything...
Old 06-11-2013, 08:15 AM
Checked my tire preasure and one tire in the rear had was alot higher than the others. Also torqued the lug nuts to the correct torque and looks like that was the problem. Am still going to get my tires aligned just to be sure... Thanks for all the input...
Old 06-11-2013, 10:54 AM
tanprotege's Avatar
You are welcome!
On a day without wind find a nice even road and go about 40 mph. Release the steering wheel, but keep your hands right there. Does it pull right or left? If it pulls right it may be caused by the crowning of the road. If you can go safely into the left lane repeat the test. If should go slightly to the left now. That means the alignment is o.k.
If it pulls to the same side on either side of the crown it means your alignment is off.
chipri60
04-09-2012 07:38 AM
bonessk01
09-08-2011 07:58 AM
GMM
06-06-2009 06:22 PM
Jean Claude
01-12-2009 07:18 PM
el cheffe
10-25-2008 10:44 PM
Quick Reply: 1998 Mazda B4000 vibration at around 70MPH
