Engine Error Codes?
Old 04-22-2007, 04:52 PM
novaman64's Avatar
Default Engine Error Codes?
I have a new ECU (AvPro Rebuild) and also jsut popped in a new o2 sensor, and I am still getting error code 17 (1 long, then 7 quick blinks). Does anybody know what this error code means? I am getting 14-15 mpg so I am guessing the 2 are related.... Maybe my mass air flow sensor is going bad?
This is in a 1991 B2600i 4x4, 5 speed...
Old 04-22-2007, 06:23 PM
Default RE: Engine Error Codes?
oxygen sensor feedback system. (according to chilton workshop manual)
Old 04-22-2007, 09:05 PM
novaman64's Avatar
hmm.... I jsut repaced the o2 sensor... do you think my new one is faulty or is there something else in that loop tht goes bad??? Any advice?
Old 04-23-2007, 12:11 PM
mxer201's Avatar
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
I think you are getting a code 17. This link should explain the codes. You might want to double check the polarity of the wires if you used a universal type o2 sensor. Good luck.
Old 04-23-2007, 01:25 PM
novaman64's Avatar
I got a o2 sensor that already has the OE connector installed on it so theres no way the wires polarity could be swapped... Any other ideas?
Old 04-23-2007, 10:39 PM
Disconnect the HO2S. ([*]
Measure the resistance between PWR and GND terminals of the sensor. If the reading is approximately 6 ohms at 68°F (20°C). the sensor's heater element is in good condition. [*]
With the HO2S connected and engine running, measure the voltage with a Digital Volt-Ohmmeter (DVOM) between terminals HO2S and SIG RTN (GND) of the oxygen sensor connector. If the voltage readings are swinging rapidly between 0.01-1.1 volts, the sensor is probably okay. [/ol]
simmonsp5
09-21-2023 04:49 PM
believe1470
02-27-2007 10:00 PM
CardsFan420
11-08-2006 06:25 PM
poet1234567
08-16-2006 11:52 PM
lightnix
11-07-2005 10:27 PM
Quick Reply: Engine Error Codes?
