Mazda B-4000 4.0
Old 07-21-2015, 05:55 PM
Dave De's Avatar
Default Mazda B-4000 4.0
I was talking to a mechanic today about timing chains on the Ford 4.0 engine. He said he recommends a re-built engine when you need to replace the timing chains because of the amount of work & a better warranty.....any thoughts out there would be welcome
Old 07-21-2015, 09:00 PM
dragonmp5's Avatar
Talk to a different mechanic. He sounds biased against fords. What mileage is on the engine?
Old 07-22-2015, 04:46 PM
Dave De's Avatar
it only has 90k on it. It does blow to have to remove the engine for a timing chain, but I cant believe it would be the way to go cost wise!
Old 07-22-2015, 10:44 PM
dragonmp5's Avatar
A timing chain shouldn't be bad after 90k miles, its the timing belt that need to be changed more often. You should get a lot more miles before needing it if you've been taking care of your truck.
Geilarin
04-10-2014 04:33 PM
wahoo
10-22-2008 03:49 PM
Lopaka
12-13-2007 07:05 PM
Wanderer
11-20-2007 04:28 PM
Bill Hicks
12-20-2005 12:38 AM
Quick Reply: Mazda B-4000 4.0
