1990 B2600i stalls on deceleration
Old 09-03-2012, 10:57 PM
bhowell's Avatar
Unhappy 1990 B2600i stalls on deceleration
1990 B2600i 4x4 My truck stalls when decelerating at a stop sign. It seems to run fine when cold just when it gets warmed up it stalls. Also it seems to run fine on the interstate. I've check for vacuum leak and have not detected anything. The cap, rotor, wire and plugs are fairly new. less than a year old.
The problem seems to start up quickly.
Any suggestions? Thanks
Old 09-04-2012, 04:16 PM
tanprotege's Avatar
There are a lot of other things that you can check or clean without spending much money:
MAF sensor, Intake air temp sensor, EGR valve, clean throttle body, clean EGR ports, Idle air Control valve and so on.
I hope you stumble on the cause of your problem.
Old 10-27-2012, 08:27 PM
bhowell's Avatar
I found that there is a port on the back of the intake manifold that was missing a plug. Once I installed a plug it did not stumble at a stop light any more. Thanks for the advice
Old 10-28-2012, 08:31 PM
tanprotege's Avatar
You are welcome and thanks for the feedback!
Psyleid
01-20-2010 04:41 PM
hugh2293
09-29-2009 07:37 PM
eeuler
07-10-2009 03:50 AM
OdysseyExplorer
06-25-2008 07:21 AM
Bubbles
04-26-2007 07:03 AM
Quick Reply: 1990 B2600i stalls on deceleration
