1990 B2200 CYL. HEAD
Old 01-02-2008, 10:31 AM
oldskiman's Avatar
Default 1990 B2200 CYL. HEAD
HAVE 90 B2200 WITH REPEAT HEAD GASKET FAILURES. IS THERE SUPPOSED TO BE SOME SORT OF ALIGNMENT PIN OR DOWEL TO POSITION THE HEAD ON THE BLOCK? OUR UNIT DOES NOT HAVE ANY.
Old 03-03-2008, 07:53 AM
Default RE: 1990 B2200 CYL. HEAD
Did you ever fix this, and what ended up being the problem?
Old 03-05-2008, 09:27 PM
their should be dowel pins toposition the block but i'm not sure if that is what is causing the problem.
Old 03-05-2008, 09:32 PM
There are pins to use when lining this up and also have you checked to make sure the head isn't warped or isn't planed right?
clicheche09
11-28-2009 06:41 PM
imchilean
01-08-2008 06:36 PM
imchilean
11-16-2007 08:36 PM
shawnkilpatrick
07-23-2007 01:04 PM
Quick Reply: 1990 B2200 CYL. HEAD
