Go Back   Mazda Forum - Mazda Enthusiast Forums > Mazda Vehicles > Mazda Pickup Trucks
Sign in using an external account
Register Forgot Password?
Search
LinkBack Thread Tools Search this Thread
Old 10-21-2010, 08:44 PM
Default 1988 Mazda B2200 with NO SPARK!
My old trusty Mazda B2200 decided to crap out on me the other day and it has no spark.
I had my coil tested and it came back poorly so I replaced to coil but still nothing.
Click the image to open in full size.
When my key is on, both sides of the coil pack are hot. The center is only mildly hot (dim test light). While cranking the engine over: same thing.
Where is the Ignition Module located? Could it be anything other than that?
I have no spark coming OUT of the coil, brand new coil. I tried grounding the - coild side to the - battery but I don't think you are supposed to do that and it didn't work anyways. Thanks in advance!
Register today for free or log-in if already registered to remove this ad!
Old 10-22-2010, 10:23 PM
Maybe bad points? or a bad pick up coil? Did you check to see if the distributor shaft isn't broken.
Old 10-25-2010, 11:56 PM
There is no spark coming directly from the coil so that is before the distributor. I need to figure out why there is no spark coming from the coil before I can move further down the line.
Old 10-26-2010, 11:43 PM
The coil sparks when the points break. check the points, and the ballast resistor.
Tags
1988, 2200, 88, b2200, ballast, coil, distributor, mazda, pick, producess, resistor, spark, state, testing, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Med Center Mazda
Pelham, AL 35235
© Internet Brands, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
