mazda mx-6 4cyl. wont start
so heres the deal, i have a 93 mx-6 4 cyl. the thing wont start. it turns over and will rev til the battery dies, but it will never start. it happend out of no where. Oneday it was running fine, the next it wouldnt start. Im thinking is the distributor, but there are some other modules that it could be. Has anyone else had this problem before i spend $250 on a new distributor? thanks
RE: mazda mx-6 4cyl. wont start
I have the same problem...sort of, i can start when the car is warm but its impossible when cold. I checked everything i could including the fuel injection and chassis electrical system but its like im either not getting enough juice or something is sticking when the car is cold.
Hi there? 'newbie on the scene' that's me.. please check your earth cable from your battery and replace it if possile.
before replacing it you can double check by, bypass your earth with another one,, same thickness, and your should start even when cold..by the way if that don't work try same process with your car earh centre..
bottom line is u a likey to have a broken 'internally' cable as thick as they look.
regards
regards
Backinthday
01-30-2007 02:22 PM
