Engine wont start
Engine wont start
I'm new to the forum and just bought a 93 MX6 with a 2.0 4 banger. I am having a problem with the car starting. Problem is when i put the key in the ignition and turn to start all lights on the dashcome on as usual but nothing happens, engine wont even crank over at all. It has done thisa few times in the past couple daysbut usually after the second or third try it starts right up. PLEASE HELP....
RE: Engine wont start
Is your new vehicle a Manual Transmission or an Automatic Transmission?
If it is an Automatic Transmission one problem might be the "Park Interlock Switch".
This device will not allow the vehicle to start unless the vehicle is in Park or Neutral.
You can try moving the gearshift all the way into the Park position or try to start the vehicle in Neutral.
Hope this helps.
Hope this helps.
