93 Mazda MX3 CEL Code - Dies during Idle / Giving Gas
Honda guy here that just got ahold of a 93 MX3. learning the ropes..
Car runs but will die during Idle. Also, giving it gas will kill thre motor
quickly. Sometimes, when given a lot of gas (3k range on the tach), the motor will run until letting off the gas.
I jumped the diagnostics and am getting a 1 (long) and 8 (fast)...which is giving me code 18. However, when I look up the error codes for 93 MX3s, there doesn't seem to be a code 18. Someone on YouTube also has this exact problem with a 93 MX3..and has received no answers.
One time, I also got a 3 in between the 1 and the 8. But the 18 comes back continuously.
Engine sounds good otherwise (when running)..
Any help would be appreciated.
Just a thought, if you've gotten a 3 in between the 1 and the 8 then you may have 2 different codes, 10 and 08... both related to air intake
10 Intake air temperaturesensor (IAT)
08 Volume Air Flow sensor(VAF)
03 'G' camshaft positionsensor.
kenyasing
07-29-2007 10:03 AM
