shaking badly
Old 10-05-2006, 04:06 PM
supermanwithheat's Avatar
Default shaking badly
My 93 mx6 shakes a lot from the front passenger side. this happened after i changed the axle and got an alignment. any suggestions what it might be?[&o]
Old 10-05-2006, 07:53 PM
bkey71's Avatar
Default RE: shaking badly
Was it shaking after the axle replacement but before the alignment too?...or after the combination? First thing I think of is the axle is not set all the way into the trans or the bearing on the steering knuckle.
Old 10-11-2006, 01:44 AM
its between the combination, inbetween that trip there wasnt any shaking that i remember, but it might be the knuckle like u said
Old 02-06-2007, 02:23 PM
It's the axle, did you change both of them? Make sure you know which one is causing the vibrations and replace it. (sounds or vibrations from one side may be caused by the other). You should run very smoothly.
knucklehead11
06-06-2009 07:14 PM
streetmechanix
04-24-2009 08:40 PM
curtis b
04-08-2007 04:24 PM
curtis b
04-06-2007 04:44 PM
hinrichsscott
04-17-2006 04:50 PM
Quick Reply: shaking badly
