starting prob mazda mpv
Old 10-17-2014, 07:31 AM
malcolm123's Avatar
Default starting prob mazda mpv
hi
I have a 2003 mazda mpv diesel
looking for advice on my starting problem
I some times go to start it and it turns very slowly then leave it for a while and it then cranks ok and the engine starts
I can run all day when started but when I stop and then go to start again it cranks slowly again leave it for a while and it starts ok again.
today when I got in the car it would not crank I could hear the starter clicking in after a few turns of the key it started to crank but very slowly
hence the car would not start. I had a check on the battery a while ago and the mechanic said it is fine
any ideas would be appreciated
regards
malcolm
Old 10-17-2014, 09:25 AM
hixx's Avatar
Classic starter symptoms. Check all connections and replace the starter.
Old 10-17-2014, 10:50 AM
malcolm123's Avatar
thanks for that im only hoping its connections or bad earthing
regards malcolm
Old 10-17-2014, 11:03 AM
hixx's Avatar
Since it is a diesel engine it has massive compression compared to a gasoline engine. That means the starter works really hard. Be careful of your replacement choice. A cheap starter won't last long.
Old 10-17-2014, 11:18 AM
malcolm123's Avatar
thanks
Old 10-17-2014, 11:28 AM
malcolm123's Avatar
hi again
do you know a quick test to prove the starter motor
malcolm
Old 10-17-2014, 01:15 PM
malcolm123's Avatar
hi again
just had my son round and we put jump leads on from his jeep
and it fired up first time could this meen my battery is goosed
Old 10-17-2014, 01:28 PM
hixx's Avatar
Most part stores will test the battery and starter draw.
Old 10-18-2014, 12:46 AM
malcolm123's Avatar
ok thanks
ive got it in a garage this morning to check
leads etc
thanks Malcolm
ps will let you know of outcome?
DriftKingBP
11-21-2006 11:26 PM
cugene
11-19-2006 11:58 PM
dnc8203
09-16-2006 03:04 AM
violenza
03-18-2006 04:05 PM
Quick Reply: starting prob mazda mpv
