Sliding Door Lock/Unlock
Old 09-28-2014, 10:59 AM
Ericson A's Avatar
Unhappy Sliding Door Lock/Unlock
Hi,
I've got a 2000 MPV DX van.
Before I was able to lock and unlock the sliding doors from the master switch. But now whenever I press to unlock the doors everything works except the 2 sliding doors. This van has to sliding doors by the way. I've checked the fuses and it's good. What's the next thing I should do? I'm not sure which wire to test if the master switch is giving power to the door actuators.
Any help would be great. Thanks.
Old 09-29-2014, 03:56 AM
Is there a panel of copper/brass terminals that make contact between each door and the pillar when closed? If so, clean both sides and recheck the locking.
Diagram may be of a later model, but similar principle.
Van Cafe: Vanagon Parts - Sliding Door Contact | Power Door Locks
Google Image Result for http://www.van-cafe.com/shop/images/253.959.375.jpg
https://www.google.com.au/search?q=M...60%3B418%3B357
Old 09-29-2014, 07:45 PM
Ericson A's Avatar
Okay, I'll try that. I'll let you know. Thanks.
Old 09-30-2014, 08:50 PM
Ericson A's Avatar
Hi,
I've tried cleaning the contacts and they're clean as a whistle both on the door and the frame of the door where it latches in.
Any other ideas?
Is there a way for me to check if there's power going to the actuators? Where would I be looking at the master switch?
Thanks.
Old 10-02-2014, 06:08 AM
When you press the lock & unlock button there will be a power signal at 1 or more of the terminals on the door pillar. Use a multimeter or LED testlight to check.
Tanklin23
02-01-2015 10:17 AM
fill92
06-02-2011 06:44 PM
famendo
11-13-2007 12:13 PM
cincera
03-06-2007 05:20 PM
Quick Reply: Sliding Door Lock/Unlock
