Rough Shifting out of second gear - Mazda Forum - Mazda Enthusiast Forums
Thread Tools Search this Thread
Old 08-16-2008, 08:24 PM
Default Rough Shifting out of second gear
As a new member to this forum I hope to get some help with a question I have about rough shifting on a 2004 MPV LX with 73,000 miles.
This year we replaced a throttle position sensor andan ignition coil after van acted like it was not shifting past second gear and would not go faster than 40 mph without jerking and acting like it was going to just die out on the interstate (I 95 in Washington DC while everyone else was going 85).
Recently I get the same thing again, some rough shifting from 1st to second. Almost feels like I have been hit from behind when I take off. The engine light came on and then went off again.
Should I be expecting the worse (like I need a new transmission) or could it still be the ignition coil failing again?
I would like to see if this is common in the MPV. Never had any problems with my 2000 Protoge.
Before I go to the MAZDA dealer (which has been very helpful in the past.), I wanted to get a sense of what is the worse case senario. My previous repairs were very inexpensive ($100) or so.
Thansks in advance for any opinions or comments.
Old 08-24-2008, 07:35 AM
Default RE: Rough Shifting out of second gear
Based on the other similar problems with other owners, it sounds like two things. First the tranny banging problem could be with the programming since they change gears electronically or the rough running problem might be a coil pack which was similar on my 04. The dealer can reprogram the tranny. Hope this helps.
Thread Thread Starter Forum Replies Last Post
Bucking after shifting into 2nd gear stevenhs General Tech 0 03-19-2015 09:08 PM
gear not shifting hondavespa Mazda MPV 0 06-22-2010 08:17 PM
2004 Mazda 3, 2.3 - Loss of power between first and second gear DreadPir8 Mazda3 12 05-01-2010 04:42 PM
Sloppy shifting in 2nd gear Nebfire Mazda3 13 07-22-2009 10:27 PM
shifting problems out of 3rd gear..... the_gray_mazda6 Mazda6 6 11-24-2005 02:56 AM
Tags
1st, 2000, 2nd, coil, common, gear, ignition, jerks, mazda, mpv, rough, running, shift, shifting, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
