MAP Sensor Location
Old 06-16-2013, 07:42 PM
shaggyman's Avatar
Default MAP Sensor Location
Searched high and low for hours, but I cannot seem to find a definitive description or photo of where the MAP is on a 2001 MPV.
Engine will idle fine, but there is no power and pedal to the floor takes about three seconds to reach 5000 RPM in neutral.
Replaced fuel pump, MAF, IAC, and all six spark plugs, but no change.
CEL is setting a code for the MAP, but I can't find the thing.
Anyone got any hints?
Old 06-16-2013, 10:54 PM
tanprotege's Avatar
MAP stands for Manifold Absolute Pressure. Mazda has used another nickname for the same thing: EGR Boost Sensor. Nothing gets boosted here. In my Mazda protege that EGR boost sensor sits at the fire wall, passenger side and there is a vacuum line going down to the rear of the manifold. When I pulled it off and stuck a wire in there I felt resistance. The nipple was blocked with deposits! I scraped it open and put a new vacuum line on. After that the EGR boost sensor was measuring again what it supposed to measure: the manifold absolute pressure.
It is not a good approach to throw parts at a CEL.
Old 06-17-2013, 04:59 AM
Boost sensors were a common fault in tributes,
Old 06-17-2013, 08:20 AM
shaggyman's Avatar
Friend's car: Parts got thrown by a repair shop in response to other codes.
So: MAP is mounted on the airbox, with the vacuum line fed from the EGR Solenoid....
Shop put in wrong plugs and no wire set, didn't check coil output, etc.
I doubt they did an exhaust back pressure test either.
oguzakyuz
05-01-2016 12:07 PM
palffy
07-22-2015 07:58 AM
samsquanch
05-12-2011 04:07 PM
gangst
02-22-2008 08:42 PM
caradat
02-06-2006 04:40 PM
Quick Reply: MAP Sensor Location
