Engine Stalls only during right negotiating turn.
Mazda 2000 MPV 2.5L V6 Petrol.
Recently just changed the Intake Valve gasket and things started happening.
The MPV will ONLY stalls when negotiating right turn (when engine is idling ). Other than that it's perfect !!! Had changed also the petrol pump and filter unit as first suspect the culprit but it's not.
Wondering what went wrong? as it will only STALLS during negotiating the right turn? If i press some fuel during the right turn then it's ok.... but almost every negotiating right turn will have to brake (engine will idle) and turn... then it will STALLS.
URGENTLY needs some advise.
Previously before stalling when negotiating right turn (when engine is idling ), i did change new spark plugs as well and the new valve intake gasket then this problem sets in.
I used back the old spark plugs and sprayed clean the IAC and throttle body using carborator cleaner spray and everything came back to normal.
Currently will use back the old spark plugs as changing the back to the new spark plugs quite a hassle as i would need to dismantle the top air valve manifold cover to do it.
Things now back to normal and i am glad my babu is on road with me again.
Thanks again folks.
Thanks again folks.
Wooters
02-23-2012 07:03 PM
mazda_minitruck92
11-06-2007 08:22 PM
