1992 MPV "NO" sparks
Old 10-02-2008, 10:01 AM
jarrison's Avatar
Default 1992 MPV "NO" sparks
need help, not a mechanic myself. i used my van 2 days ago and i kept it idling and then stalled. tried starting it. all it does is spins my rotor also spins so my timing belt is ok. yesterday tried disconnecting fuel lines after the fuel filter a do get lots of fuel coming out of the hose. read manuals pulled out spark plugs and place the tip at least 1/4" to the ground NO sparks tried the high tension wire did the same thing still NO spark. checked my ignition coil also replaced it still NO spark what could it be the problem i'm thinking of replacing my igniter. i have no idea if that's causing it. Thanks
Protege23
12-16-2021 09:27 AM
titan636
06-25-2013 01:16 AM
nkduncan
05-09-2012 11:44 AM
seto
01-21-2012 08:43 AM
jasonlmrx
05-02-2009 05:22 PM
Quick Reply: 1992 MPV "NO" sparks
